On-Demand Acquisition time-stamp issues
Hi all,
In reference to a problem I had earlier regarding Labview (http://forums.ni.com/t5/LabVIEW/incorrect-time-data-after-reading-measurement-file/m-p/2341184#M7324... I soon realized that it was a data acquisition issue rather than a Labview issue hence my post on this board.
To elaborate, I have a M-series PXI-6221 DAQ that I used to collect data with on-demand timing. This results in multiple data points being seemingly written to the same time-stamp. I attribute this to the DAQ reading as fast as it can, and subsequently generating these timing glitches. Normally, this wouldn't be a problem in a graphing program set to scatter mode, but it does pose significant challenges when I try to process this data in Labview since the timing is completely changed.
Is there a way to stop the DAQ obtaining data points in such a fashion? I was thinking of placing a time delay of 1 ms or so, but that seems like a very crude method of solving this problem.
(2,986 Views)
Hello mlau,
You could use continuous sampling instead of on demand. Use a sampling rate of 1000Hz for data points every 1ms. (Frequencty = 1/Period)
Thank you,
Joel Carroll
(2,974 Views)
