One DAQ 6036E card and two CB-68LPR connector blocks
Good morning,
I have got a PC computer with LabView RealTime 11 OS installed on it. This computer has NI PCI 6036E DAQ card and it is connected to CB-68LPR connector block to acquire signals from work station. In laboratory, there is another work station and I would like to acquire signals from it too, but there is no free channels on DAQ card, so I wonder If i could buy abother connector block and acquire signals from both work stations using one DAQ card and two connector blocks separately (not at the same time, ) obviously using different labview programms. So it would be:
-connect first connector block to pc computer
-turn on labview programm and acquire signals from first work station
-turn off computer and connect the second connector block to the same DAQ card
-turn on second labview program and measure signals from second work station.
To conclude, may I have some communication problems or any other difficulties when my 6036 DAQ card will cooperate witd two CO-68LPR connector blocks (but not at the same time).
Than you very much for answering me, I am aware, that is not a big problem and I think that it will be working, but i need another opinion.
Best regards, Pawel.Smiley Happy
(3,931 Views)
It should work just fine.
(3,908 Views)
Thank you very much. Do you or anyone else know if it is easy to damage connectors ?
(3,904 Views)
It's pretty easy to damage the male ends if you are not careful. Make sure you push/pull straight on. Don't yank. You probably want to be disconnecting the cable at the CB-68 end. If a pin gets bent, you can often gently straighten it with a pair of long nose pliers.
(3,900 Views)
Of course, thank you once again.
(3,895 Views)
Yes, I will be disconnecting the CB-68LPR end of the connecting cable.
(3,886 Views)
