Open Traditional NI VI file using Labview 8.5
I want to open this VI that I attached below using labview version 8.5
But when run this VI, the error message pop out like below:
I suspect this VI using traditional NI component.
How can I run this VI using my current version of Labview?
Thanks in advance
(3,048 Views)
Accepted by yusof
Yes, you're right. These are Traditional DAQ VI's.
Install Traditional DAQ 7.4.4 (WXP or W2000) and ensure to enable the LabVIEW support while configuring the installer.
PS : LabVIEW 8.5 and Traditional DAQ are not supported by W7. See here (OS<-->LV) and here (DAQ<-->LV).
(3,047 Views)
