02-10-2008 11:03 AM
02-11-2008 03:44 PM
dikkon,
The reason for the error is due to the fact that NI’s HSDIO products are not supported in Linux.  You can find that information here and from the readme file for the NI-HSDIO driver.
Also, NI does not officially support the Fedora distribution. The three Linux distributions that are supported are SuSE, RedHat and Mandriva.
If your application allows it, you could use an M-Series device with the NI-DAQmx 8.0 driver for RedHat. Since Fedora is the community version of Red Hat this could be a possible starting point. Also, the M-Series is functionally different than a HSDIO card, so make sure to compare and contrast the two before making a choice. Again, this workaround has not been tested by NI and is not guaranteed to work.
Ryan N
Application Engineer
02-11-2008 04:03 PM
02-11-2008 06:57 PM
dikkon,
You are correct in saying that the PCI-6534 is supported in DAQmx 8.0, however DAQmx 8.0 is not supported in Fedora 7. Due to the fact that there are many distributions of Linux out there, NI had to choose a few to officially support. For support on other distributions of Linux the NI online community is the best place to look for answers.
1. Have you seen this discussion forum?
2. What resources did you use to install DAQmx 8.0?
Additional resource may be helpful to the NI Linux community. I would also recommend reading some of the other posts in the forums for Fedora Core 5, 6 and 7.
Ryan N
