PCIe-6320
Good morning,
I am interested in purchasing the PCIe-6320 board to acquire real-time signals and connect it to my laptop. I would like to know if, since it uses a PCI Express interface, it is compatible with the NI SC-2075 signal conditioning board, or if it would be necessary to purchase a different interface board.
Additionally, I would like to know if the PCIe-6320 can operate correctly when installed in a StarTech.com Thunderbolt 3 to PCI Express Expansion Chassis with DisplayPort (PCIe x16), in order to connect it to my laptop via Thunderbolt.
Thank you in advance for your support.
(976 Views)
SC-2075 has been long obsoleted and is not compatible with PCIe-6320.
Is there any reason why you want to use a PCIe form factor of DAQ?
Why not NI mioDAQ Devices that can connect to a USB-C port directly?
(963 Views)
I need to use the PCIe-6320 with Simulink Desktop Real-Time, which is not compatible with USB DAQ devices due to the inherent latency and non-determinism of USB communication.
Regarding the SC-2075, why do you mention it is not compatible? As far as I know, it is designed to work with X Series DAQ boards like the PCIe-6320 via the correct shielded cable (e.g., SHC68-68-EPM).
Could you please clarify this point?
Additionally, do you have any recommendations for a compatible BNC terminal block or signal conditioning solution that can be used with the PCIe-6320?
(955 Views)
