PXI Express chassis and module compatibility
Is NI PXIe-4339 and TB-4339C compatible with PXI Express 1092 chassis?
(1,397 Views)
Accepted by cynth__77
Yes, it is compatible.
There are 7 PXIe hybrid slots in 1092 chassis and you can install 4339 in any of them. The easiest way to identify is to check if both the chassis and the module have the same PXI version, in this case, both the chassis and instrument are "PXIe".
Santhosh
Soliton Technologies
(1,394 Views)
That was helpful. Thankyou!
(1,390 Views)
