Multifunction DAQ
Phase Angle Measurement isnig DAQ 6009
Hello ,
I am measuring two analog signals with the USB DAQ 6009,I wonder if anyone has a tip,
or know any tool for phase angle measurement of these signals using LabVIEW. Thank you Ednaldo Cruz
(3,810 Views)
Accepted by EdnaldoCruz
Have a look at the extract single tone iunformation vi  found at signal processing-measurements
Capture > 10 periodes
Keep in mind, that you have a multiplexed input, so you will measure a certain delay in any case.
(apply the same signal to both channels, for each samplerate used, measure the phase, calculate the 'group delay' for correction)
Greetings from Germany
Henrik
LV since v3.1
(3,800 Views)
Thank you,
really helped me a lot, man!
Greetings from Brazil .
7x01 :,(
(3,750 Views)
