Plotting acquired data against timestamp
I followed the reply on 'How Can I Plot My Acquired Data Versus A Timestamp in LabVIEW?' but am still unable to plot my acquired data against its corresponding timestamp. There is a problem with the data types which I don't understand. Can you please help?
(4,900 Views)
Accepted by Danilson
Hello Danilson
I have written you some example code that you can you to change the time stamp values of the waveform. Originally you where trying to build a cluster, which is an object that contains independent variables.
I hope this is helpful
Philip
Philip
UK Branch
===If this fixes your problem, mark as solution!===
(4,877 Views)
Can I get it under 8.5 version. Thanks!
(4,701 Views)
Here it is.
Philip
UK Branch
(4,698 Views)
I am trying to do something similar but, from my waveform, I average 100 values, then I want to plot the averages vs. a timestamp.  Since my data is no longer a true waveform, I can't use the "build waveform" VI.  Is there another way to do this for my data?
Thanks!
(4,604 Views)
Hello Adwhit
With the Convert to Dynamic Data type config like this.
Phil
Philip
UK Branch
(4,584 Views)
