Multifunction DAQ
Python NI-DAQ multi-board acquisition
I'm using two PCIe 6259 boards connected with an RSTI cable. I'm using the Python NI-DAQmx library to control them. I have used these boards in MATLAB for multi-board acquisition but I keep getting boards can't be used, the error is: "nidaqmx.errors.DaqError: One or more devices do not support multidevice tasks. Device: Dev1 Device: Dev2"
N = 512
sampleRate = 110e3
readTask = daq.Task('readTask') # Create analog read task
readTask.ai_channels.add_ai_voltage_chan('Dev1/ai0', terminal_config=TerminalConfiguration.RSE)
readTask.ai_channels.add_ai_voltage_chan('Dev2/ai0', terminal_config=TerminalConfiguration.RSE)
readTask.timing.cfg_samp_clk_timing(sampleRate, sample_mode=AcquisitionType.CONTINUOUS, samps_per_chan=N)
reader = readTask.in_stream
readTask.start()
attached below is te full script I just want help understanding how to connect the boards.
(1,701 Views)
Did you Registering Your RTSI Cable in MAX?
To create a multi-device route, the source and destination devices must share a trigger bus both physically and logically in MAX. For PCI devices, you must register your RTSI cable in MAX.
See Real-Time System Integration (RTSI) and Configuration Explained
https://tmesystems.net/
(1,689 Views)
I have registered the RTSI cable with MAX. I have done a little more research and found out that PCIe-6259 is an M-class device, so it does not support multi-device tasks. So I'll have to figure out how to synchronize them with separate tasks. So all my code is useless.
(1,681 Views)
Accepted by topic author DiegoBoulder
Good catch. In that case, you would need two separate tasks. You can refer to nidaqmx-python/examples/analog_in/ai_multi_task_pxie_ref_clk.py at master
(1,640 Views)
