Read the voltage of CJT thermistor in SCXI 1112 module, revA
The KB does'nt answear the question. I've tried every combination of physical channel names but this hasn't worked such as ob0~sc1!md2!cjtemp0 (cjtemp-1), SC1Mod2SC1Mod1/_cjTemp0 etc. Below is the vi that I'm using. Shouldn't the channel appear when browsing the list of physical channels?
(2,563 Views)
Steve1,
Yes, the channels should appear in the drop-down list. Make sure you have your SCXI chassis configured properly under NI-DAQmx Devices, not Traditional DAQ Devices. As a side note, what errors are you receiving when you try to run your program? This may help in troubleshooting. Have a great day!
(2,563 Views)
