Recommendation for DAQ card
Hi Guys, 😃
I´m currently developing a project in a gas control, where I need to meassure tempertures and be able to open and close a valves.
My set up are 4 termocouples and 4 relays for switching On and Off this valves..
I was wishing if someone could help me to choose an DAQ card for both things. where it has 4 analog inputs for
thermocouples and 4 digital (5v) outputs for 4 the relays. and preferably be able to use them on the same DAQ card, for PCI o USB. or
use a DAQ card for input and another for the Output..
Thermocouples are type K..
Tnx in Advance..
Sincerly
Luis Alonso
(3,870 Views)
Anyone?
Tnx Again...
(3,850 Views)
bump
(3,832 Views)
Accepted by Luigi77
Hi Luis,
How much current do the relays require? Does the combination of a cDAQ-9174, NI 9211, and NI 9401 sound like it would meet your requirements? You may also want to look into devices that have built-in relays, such as the NI 9481 or PCI-652x.
Brad
Brad Keryan
NI R&D
(3,813 Views)
Hi Brad...
Tnx alot man.. I dont know the relays characteristics yet, but I guess I´ll use the proposed setup you
recommended me...
Luis
(3,782 Views)
Hi Luis,
It would be better to get the relay specifications and figure out whether the DIO module can source enough current before making a purchasing decision.
Brad
Brad Keryan
NI R&D
(3,769 Views)
