Multifunction DAQ
SPI Protocol for NI -6365
I do have the NI-PXIe 6365 DAQ installed and would like to analyze a SPI-Interface. Is there a protocol analyzer available which can be used?
Thanks in advance!
(1,058 Views)
Accepted by Norick17
This is just a multifunctional DAQ, you can capture DIO lines as waveform and analyze them using your own utility or implementation.
This may be helpful for you - https://forums.ni.com/t5/Example-Code/Simple-SPI-Read-with-NI-DAQmx-DIO/ta-p/3535624
Santhosh
Soliton Technologies
(1,054 Views)
