02-25-2009 04:05 PM
To whom it may concern:
I am using an NI-PCI 6221 with Labview 8.0 Currently, I load a waveform onto the boards buffer and then trigger it to output using a separate channel. The waveform outputs correctly, but once it stops, the output of the board will not always be zero. Rather, it will be at the last value of the board's output. How can I have it reset to zero?
Thank you for your help.
02-26-2009 09:07 AM
