Syncronizing ADC clock and DIO clock
I am trying to syncronize the AI Sample clock and the digital output clock.  I am running a time division multiplexed (TDM) system, so the clocks are incredibly important.
I am trying to generate one clock that is 10x faster than another.  (I need to send a few commands to the multipexer and give it time to settle before I sample the ADC.  I picked 10x because that seemed like a good idea for the PLL divider but can really be any number between 6 and 20).
If I run the system at 10KHz, the clocks are perfect.  (I measured this on a scope by measuring Cntr0 Out and Cntr1 Out).  However, if I run at say 11KHz, the clocks are off enough that over time, the multiplexer gets off an entire channel and all of the channels mix into another channel.
I would greatly appreciate any advice on how to best handle the clocking.  I have attached my VI.
Message 1 of 17
(4,288 Views)
Attached is a screenshot showing the Counter 0 and Counter1 outputs for different frequencies (10KHz and 11KHz).  Notice that the markers show that the 10x is not preserved.
Message 2 of 17
(4,282 Views)
Hi SuperSnake428,
Let me get some more information to more fully help you. What hardware are you using? What version of LabVIEW, operating system, etc. do you have? I want to make sure I address all your needs instead of just patching one part.
In looking at your example code, it appears that counter1 is being triggered off of counter0, which could be one source of synchronization error.
Also, 11kHz is not an exact division of a card’s timebase (20MHz or 80MHz), meaning you don’t get a true 11kHz, whereas 10kHZ is 10kHz. That could introduce some error over time.
I will probably be able to formulate a concrete solution once I understand your setup better. I look forward to your response.
Mark E.
Precision DC Product Support Engineer
Message 3 of 17
(4,271 Views)
Labview 8.2 on windows xp
M series 6281
It seems to me I should generate the high free clock and then divide that one down, this way the 10x is garunteed
Drew
Message 4 of 17
(4,269 Views)
Don't have LV nearby to look at code but as Mark said, the internal timebase prevents you from generating a signal at *exactly* 11kHz or 110 kHz.  If you generate them independently, you can't count on them having an exact 10x relationship because they will quantize to 10.9996 kHz and 110.041 kHz.  (Or something like that -- I assumed rounding to nearest possible freq, the actual algorithm might do its rounding differently.  Either way, you get small discrepancies due to quantization.)
Your recent comment is exactly correct -- if the 10x relationship is crucial, the easiest implementation is to use the high freq clock as the timebase for the low freq clock.  Then you can program the low freq clock to get an exact divide-by-10.  It's especially easy here to use units=Ticks and you can just provide integers for low ticks and high ticks that sum to 10.
-Kevin P.
Message 5 of 17
(4,256 Views)
So I have created the 10x signal from a counter (divided down from the 20MHz reference), and then I divide whatever that output is down by 10.  How do I actually sync the analog input and digital output though?  I have tried adding start triggers to both of the waveforms on the slower clock's rising edge, but I don't think that PFI13 can be wired into the digital start triggers like I am trying.  So if I have these two clocks, how can i force the analog and digital to start at the same time?
Drew
Message 6 of 17
(4,245 Views)
The faster counter clock acts as the DO sample clock and the slower counter clock acts as the AI sample clock, right?
Sync part 1: Be sure to configure and start the task for the slower clock *before* starting the task for the faster clock.  Even though "started", it won't produce any output clock signals until the faster clock starts giving it something to divide down.  Once it does, their timing is *necessarily* hardware sync'ed.
Sync part 2: With similar reasoning, make sure you start the DO and AI tasks *before* you start the faster clock.  Then you won't need to worry about triggering at all -- the sample clocks themselves will control the sync'ing.
Sync part 3: Phasing.  Suppose you set your low and high times at 5 Ticks each.  Then the low freq clock will put a rising edge right at the 5th, 15th, 25th, ... rising edges of the high freq clock.  If you want to skew it, you could use 8 Low Ticks, 2 High Ticks, and put edges at  8, 18, 28...
Sync part 4: Special-case phasing.  The low freq clock counter has another parameter called "Initial Delay" which can be used to make the very first Low time different from all the rest.  For example, with Initial Delay=10, Low=5, High=5, you could put edges at 10, 20, 30...
-Kevin P.
Message 7 of 17
(4,242 Views)
Kevin,
Thanks for the help.  Maybe I am doing something wrong, but this does not seem to work (I tried this earlier before I stated looking at adding triggers).  The scope shows that there are 20-40 pulses on the fast clock before the slow clock starts kicking in.  Therefore, the MUX has already started scanning across the channels.  It seems that now at least the channels aren't mixing, but I need to make sure that I am able to precisely know what channel I am sampling.  I have attached the modified VI.
Drew
Message 8 of 17
(4,237 Views)
I had a brief chance to look at the latest vi you posted.  What I saw looked like the clocks ought to work properly -- I couldn't see a reason for the behavior you observed.  The only thing I noticed was that the AO task seems not to be sync'ed to all the other ones since it doesn't update based on one of your counter clocks.  Not sure if this is your intent, but I kinda suspect you'd want it sync'ed.  Either way, it doesn't affect the sync'ing of the clocks themselves.
My only troubleshooting thoughts are:
1. Add an intermediate sequence frame between the 2 that start the tasks.  Put in a "Wait (msec)" delay there.  Start big (~100 msec) and if you get proper behavior, work your way down until it gets flaky.   This really *shouldn't* help because your sequencing should be enough.  But when troubleshooting, sometimes the stuff that shouldn't help is the stuff that does help.
2. Wire a non-zero value for the initial delay.  The smallest legal value is 2.  Your request for 0 should get turned into the smallest legal value of 2 automatically, but this simple change seems worth a try.  I'd wire in the same 5 that's used as the Low Ticks setting.
3. Question: when you run this multiple times, *exactly* how many fast clock edges occur before the first slow clock edge?   Is it consistent?  If not, list the #'s you get on 10 runs to characterize the variation.
Next, try the same experiment with the "fast clock" throttled down by a factor of 3 or so.  This probes at whether the timing discrepancy follows real time (maybe software execution related) or #'s of ticks (board hardware and DAQmx related).
-Kevin P.
Message 9 of 17
(4,215 Views)
Kevin,
I will try what you have suggested.  I will also try and get some screenshots of the scope.  I trigger off of the rising edge of the slow clock and you can see that there are many (more than a few cycles) that the fast clock has already gone through.  This is further exagerated because I have injected known signals into the multiplexer and it is off by at least 2 channels (20 pulses).  As for consistency, I haven't run it enough to verify but it hasn't (as of yet) caused the channels shown to be more than 2 off.
The wait idea is good and I will give it a try.
As for the analog output, it is unsynced.  It is simply a modulating waveform so I don't really care about it.
I'll keep you posted.  Thanks for the sugestions,
Drew
Message 10 of 17
(4,212 Views)
