Syncronizing ADC clock and DIO clock
Hi Drew,
This may or may not help, but I had been cooking this up while Kevin was helping you out. It’s an example of how to synchronize your AI and DO. I started with the shipping example “Multi-Function-Synch AI-AO” found in the Example Finder under “Hardware Input and Output » DAQmx » Synchronization » Multi-Function”. You can pair any of the DAQmx » Digital Generation examples for the DO. Depending of what you want as your output, there are a few different choices.
Hope this helps.
Mark E.
Precision DC Product Support Engineer
Message 11 of 17
(1,572 Views)
Mark,
Any chance I can get you to save that example as LabView 8.2?  I don't have 8.5 yet :<
Drew
Message 12 of 17
(1,559 Views)
Kevin,
I tried inserting the delay (2s) but it had no effect as predicted.  I also changed the initial delay to 5, but that didn't help each.  As for the exact number of cycles that the fast clock is going through, lots... i don't have a very good scope so it's hard to set a trigger to get the exact number, but lets just say it looks like more than 20.  I also added a stop and clear task for the counters just to make sure that something fishy wasn't happening there.
Any other ideas?
Drew
Message 13 of 17
(1,558 Views)
Well... Looks like its time to get a new scope (or at least learn how to use this old piece!)... I made a VI that used the NIDAQ to sample the clocks and everything works perfectly.  Thanks for all the help!
Drew
Message 14 of 17
(1,556 Views)
Hello everybody,
 I need to provide DO to the a multipexer (Pressure scanner with 16 Pressure lines , 1 AO and 4 DI) to select the desired pressure channel, give it time to settle before I sample the AI in my DAQ card. I have the following hardware :-
1.PXI Chassis 1052,
2. PXI 6221 DAQ card
3. Labview 7.1 with Win XP
Looking for valuable suggestions.
Surender Kumar
Message 15 of 17
(1,494 Views)
The above post is a duplicate. Please refer to this thread.
Mallori M.
Mallori M
Sr Group Manager, Education Services
ni.com/training
Message 16 of 17
(1,472 Views)
Here was that example saved in LabVIEW 8.0. I was in out of the office and missed this post. Sorry.
Mark E.
Message 17 of 17
(1,463 Views)
