Taking data using analog input at 40ms interval
How do I take in all 3 analog input together at 40ms interval.
Example: programme will run and programme will take in input, stop and take in input again at 40ms interval.
(3,858 Views)
You can set the sample clock to do this or put your acquisition code inside a while loop.
If you want some example code, you'd better provide the programming language you are using.
(3,855 Views)
This is a print screen of my programme
(3,849 Views)
You could instead post your actual VI. It's hard to see how you have the timing function wired, etc. It looks like you are sampling at 60000 samples/sec. I'm not sure, but I think you have it set up to acquire all of these so you will take 1 sec for each acquisition.
Message Edited by Dennis Knutson on 06-16-2009 08:26 AM
(3,846 Views)
(3,841 Views)
