To what limits (lower and upper) are the PXI-6052E boards calibrated for their various gain settings?
I am trying to get some boards calibrated by our metrology lab, but I can't find the relevant information.
(2,747 Views)
All of our current calibration information and procedures can be found at http://www.ni.com/support/calibrat/. Post again if you were unable to find the information you need.
(2,747 Views)
I've viewed all, and downloaded most, info at the link that you've mentioned. Unfortunately, the data I'm looking for isn't there. In the E Series Calibration Procedure document, there is an extensive listing of tables that contain calibration data points for a variety of E series boards. However, the 6052E board isn't listed. Elsewhere on the ni website, there is a note to use the 6034E/6035E tables for the 6052E boards. These tables do not contain all the gain settings for the 6052E. I would assume that the 6052E boards were factory calibrated at all possible gain combinations.
(2,747 Views)
