Two DAQ modules and channel configuration with API
I am using two DAQ PXI 6251 and 6259 in the same VI, can I use the one create channel NI DAQmx for the AI cHannels from both the PXI or how can I use the channel configuration?
Is this correct Dev2ai0:16, Dev3:8?
(3,352 Views)
Hi KRAZE4LV,
Attached please find an example VI of how you would configure this task.  I hope it helps!!
Kira T
(3,343 Views)
Hello Kira T
Please send the VI in Labview 2010, I cannot read your file.
thanks
(3,337 Views)
Accepted by KRAZE4LV
Hey KRAZE4LV,
Here is the VI in 2010.
Kira T
(3,328 Views)
