Multifunction DAQ
USB-6000 shows up in NI MAX, but not in NI Device Monitor, and unable to perform Self-Test
I'm having trouble setting up an NI USB-6000. I'm able to see the device in MAX, but I'm not able to right-click on it to perform a Self-Test. In addition, the device does not show up in NI Device Monitor. I'm running LabVIEW 2017 (32-bit) [f1] and DAQmx 17.1.1, but I've yet to begin trying to use LabVIEW with the device. So far, I've only tried repairing DAQmx and reinstalling it from scratch, both to no avail. Any help would be very appreciated!
(2,601 Views)
Accepted by carter252
Have you looked at our article about that behavior?
This article talks about the behavior you are describing so follow those steps and see if it solves your issue.
Casey G.
(2,564 Views)
