Now I have got the input range to work, the problem was that LabView don't update changes in the task made in "DAQmx base configuration".
Why this? And how can I manually force an update without restarting LabView?
Description of how I can reproduce the problem:
Create a AI task with range [1V -1V] , Differential, “On demand”, Save and Exit
Start Labview and do one measure using “DAQmxBase Start Task” and DAQmxBase Read
Start “DAQmx Base config…” and edit the range to [10V,-10V] Save and Exit
Run the program in LabView, result: no change the range is still +/-1V ????
If I save the VI and close Labview (just the VI is not enough) and start LabView again and open the same VI, now the range is +/- 10V.
Im using LabView 7.1
