11-27-2007 04:29 AM
11-28-2007 03:46 AM
Hi Dietrich,
Sadly I don't have access to an FC box here to try this out, however I will try this now with our Linux box to see if I can recreate the error. The error code you are seeing is to do with a firmware error on the device.
http://digital.ni.com/public.nsf/allkb/9F61B1CE00D6CE7586257204006B207E?OpenDocument
If you could also post your modules so I can see what you have installed overall on your system that would be great
"lsmod | grep ni" as root
11-28-2007 04:13 AM
11-28-2007 04:28 AM
11-28-2007 04:33 AM
Hi Dietrich,
I'm glad to hear you've solved the issue, the firmware on the USB-600x doesn't ship with base by default.
Best of luck! and thanks for letting me know you got it working,
