USB-6009 differential input isolation?
When a USB-6009 is in differential mode are the inputs (A0+/-, A1+/-) isolated?
I need to monitor an AC line voltage as well as output voltage and current on a DC power supply.
Obvously the AC and DC voltaged will be scaled. I am planning on using a shunt for the DC current.
I was hoping to get away with a simple resistor network to scale the voltages.
I am kind of leary of just hooking it up and trying it as I do not want to damage anything.Smiley Tongue
=== Engineer Ambiguously ===
(3,331 Views)
Hi RTSLVU,
Unfortunately, the analog inputs on a USB-6009 are not isolated.  If you want to bring down the voltages, I would suggest an attenuator.  The KnowledgeBase linked below has more information on measuring voltages outside the range of the DAQ card.
KnowledgeBase: Measuring Voltage Signals Outside the Range of a DAQ Board
I hope this helps!
- Erik
(3,310 Views)
