What version of DAQmx Base are you using? The latest version, 1.4, is supported on all versions of LabView 7.0 and higher. It can be obtained using the following link:
http://digital.ni.com/softlib.nsf/websearch/941677622E793A2686256F8C0083641A?opendocument&node=132050_US
