Multifunction DAQ
USB 6009 shows up in Device Manager, but not Measurement and Automation Explorer
I have a NI-USB 6009, which is visible by Windows, but not in MAX.  AM using NI-DAQmx 9.0.2 (so it should pre-date the HID/PID issue I have read about).  See attached screenshots.
I suspect I am missing something.  What??
(4,424 Views)
Expand the "Devices And Interfaces" branch of the tree at the left, that is where it should show up.
-AK2DM
(4,415 Views)
Thanks, AK, but I am aware of that.  It does not show up there.
(4,413 Views)
Hi Chris,
It sounds like it is a problem with NI software not recognizing your NI USB-6009. The most likely reason is that your "NI Device Loader" service has not started on your computer. To resolve this issue, please follow all the steps here in this Knowledge Base article.
Let me know if that works for you! Have a great day!
Peter E
Applications Engineer
(4,393 Views)
Peter,
That is not the problem.  The service was running.  Just for giggles I disconnected the DAQ, stopped and restarted the service, and reconnected the DAQ.  The problem persists.
---CJN
(4,390 Views)
Accepted by ChrisNagy
Sounds like a classic MAX database corruption.
There's methods to go through and fix that... they're rather complex and convoluted.  Easiest way is to simply uninstall/reinstall MAX.  Your version's a few versions out; 9.4.0f1 with the WinXP hotfix has worked well to fix that same problem on several machines here, looks like 9.5's out for download now.
(4,383 Views)
That appears to have worked.  I still need to apply the Hotfix, but look to be up and running.  Thanks!
(4,368 Views)
