03-05-2012 10:04 AM
I have a NI-USB 6009, which is visible by Windows, but not in MAX. AM using NI-DAQmx 9.0.2 (so it should pre-date the HID/PID issue I have read about). See attached screenshots.
I suspect I am missing something. What??
Solved! Go to Solution.
03-05-2012 01:10 PM
Expand the "Devices And Interfaces" branch of the tree at the left, that is where it should show up.
-AK2DM
03-05-2012 01:13 PM
Thanks, AK, but I am aware of that. It does not show up there.
03-06-2012 12:31 PM
Hi Chris,
It sounds like it is a problem with NI software not recognizing your NI USB-6009. The most likely reason is that your "NI Device Loader" service has not started on your computer. To resolve this issue, please follow all the steps here in this Knowledge Base article.
Let me know if that works for you! Have a great day!
03-06-2012 12:40 PM
Peter,
That is not the problem. The service was running. Just for giggles I disconnected the DAQ, stopped and restarted the service, and reconnected the DAQ. The problem persists.
---CJN
03-06-2012 01:07 PM
Sounds like a classic MAX database corruption.
There's methods to go through and fix that... they're rather complex and convoluted. Easiest way is to simply uninstall/reinstall MAX. Your version's a few versions out; 9.4.0f1 with the WinXP hotfix has worked well to fix that same problem on several machines here, looks like 9.5's out for download now.
03-07-2012 10:40 AM
That appears to have worked. I still need to apply the Hotfix, but look to be up and running. Thanks!
