I am attempting to use a USB-6211 daq to perform low voltage (<100mV pk-pk) outputs. I am using just the normal Output regeneration vi to create the output but it has very large zero crossing spikes. Now I was reading about glitching, is this what I am experiencing? And would an external sample and hold circuit alevate this problem? I did read the maxim site dealing with deglitching but I am still a bit hazy as how to actually implement it in hardware. If anyone has a more specific sample and hold implementation website using actualy hardware I would appreciate them posting it. Would i need to route my sample clock to one of the digital pins and use that as my digital control for the sample and hold?
I have already attempted to put a low pass filter on the output and this helps the problem alot, but it doesn't aleveate it to a satisfactory output.
