USB-6218 +5V Pin
Hi, I am using the USB-6218.
I have an digital circuit that I want to monitor. It has an open collector output. Am I okay to use the +5V on the DAQ to connect a pull up resistor to?
Also is it still ok to use this +5V pin for the pull up if i want to monitor this digital signal using an Analog Input?
Thanks for your help.
Daniel
(3,027 Views)
Hi Daniel,
It should be okay to use the 5V rail in both cases.  Just make sure you use a high enough resistance for your pull up so that you don't draw too much current when you drive your digital circuit's outputs low.
Way S.
NI UK Applications Engineer
(3,004 Views)
