Hi, I am using the USB-6218.
I have an digital circuit that I want to monitor. It has an open collector output. Am I okay to use the +5V on the DAQ to connect a pull up resistor to?
Also is it still ok to use this +5V pin for the pull up if i want to monitor this digital signal using an Analog Input?
Thanks for your help.
Daniel
