USB-6259 BNC
USB-6259 BNCのA/D変換とD/A変換を利用してデジタルフィルタを構成したいと考えております。
A/D変換した信号をそのままD/A変換する場合、応答速度はどの程度でしょうか。
(1,290 Views)
@kyonBB wrote:
I would like to configure a digital filter using the A/D conversion and D/A conversion of the USB-6259 BNC. What is the response speed when the A/D converted signal is directly D/A converted?
I don't quite understand your question. But the speed of ADC and DAC conversion are listed in the NI 6259 Specifications
ADC
Single channel maximum
1.25 MS/s
Multichannel maximum (aggregate)
1.00 MS/s
DAC
Maximum update rate
1 channel
2.86 MS/s
2 channels
2.00 MS/s per channel
3 channels
1.54 MS/s per channel
4 channels
1.25 MS/s per channel
https://tmesystems.net/
(1,260 Views)
Accepted by kyonBB
I believe the OP's question is what could be the latency between capturing an AI, apply digital filters, generate using AO.
@kyonBB, this DAQ is not meant for implementing DSP filters, you can achieve it at high sampling rate, but the latency will be mostly dependent on your PC's processing speed and chunks of samples you process at a time.
Santhosh
Soliton Technologies
(1,253 Views)
Thank you for your response to my question in Japanese.
(1,233 Views)
As you might expect, I intended to ask about the latency from the input signal to the output signal.
Thank you for helping me. I really appreciate it.
(1,231 Views)
