USB DAQ device 10 V output
Hi all,
I was looking for a usb DAQ device which would have two analog outputs that could range between 0-10 V. I already looked into NI's website, but the ones I found I think can only go up to 5 V. The one that I am looking for should be one of the simplest models (equivalent to usb-6008, for example).
Thank you!
(4,180 Views)
So .... any reason an op-amp with a gain of 2 won't work?
(4,177 Views)
The specification for the USB-6001 states the analog outputs (2 of them) have a range of +-10V.  Can't get much more basic than that one.
GCentral
(4,173 Views)
Thank you very much both of you. I will order the USB-6001 model 🙂
Thank you!
(4,147 Views)
