Unwanted DC offset in AO
Hi
I have an NI USB-6251 DAQ.
There is an unwanted DC offset of 10mV across my analog output.  As I want to output a sinusoid of about 0.5mVpp, this is a problem for me.
Any ideas?
Jamie
Using Labview version 8.0
(2,935 Views)
Hey Jamie,
The USB-6251 is capable of three different output ranges: ±10V, ±5V, and ± external reference (APFI0). This allows you to narrow down the range of the D/A converter and can reduce the offset caused by inadequate resolution. Check out this document on Developer Zone. There is also a LabVIEW example that demonstrates how to access this functionality.
Hope this is helpful,
Garrett H
(2,912 Views)
