VB6 6009
phsieh2005 wrote:
Hi, Jeff,
Thanks!
I have to sample 2 channels at the same time.   Is DAQmxReadAnalog1ChNsamplesdbl for just 1 channel?
Also, where can I find all the commands that are available for VB6?  So far, I have seen DAQmxReadAnalogScalarF64, DAQmxCfgSampClkTiming, and DAQmxReadAnalog1ChNsamplesdbl.  Are there others?
Pei-Ying
yes.  DAQmxReadAnalogNChNsamplesdbl returns a 2d array
Message 11 of 14
(1,191 Views)
Hi, Jeff,
VB6 cannot find either DAQmxReadAnalog1ChNsamplesdbl or  DAQmxReadAnalogNChNsamplesdbl.  Do I have to include specific componenet or references into VB6?  It did find DAQmxReadAnalogScalarF64, though.
Pei-ying
Message 12 of 14
(1,178 Views)
Hi Pei,
The Visual Basic 6 and C API use a lot of the same function calls, if you look at the DAQmx C Reference help and the DAQmx C API Visual Basic 6.0 Help. You can see what read function are avail and you can find the function prototype and definitions of these functions. The DAQmxReadAnalogScalarF64 command will only read one value from one channel the  DAQmxReadAnalogF64 can read from multiple
Matt
Message 13 of 14
(1,158 Views)
Thanks Matt,
I am much more familliar with the LabVIEW polymorphic instantces' names than the API naming conventions
Message 14 of 14
(1,157 Views)
