stop the buffer at the end or beginning so there is bumpless transfer when updating the scans in the buffer. We output a sine wave so the end of the cycle will be at 0 volts, has anyone come across this before , we are using Labview 6.1 with latest NI-daqHello,
To find which cards have onboard FIFO, please open LabVIEW Help and then the last item is Hardware Capabilities. Here you will find the hardware capabilities for a range of cards and of the fatures mentioned is Input FIFO as well as Output FIFO. This will give you an idea about the onboard FIFO for different cards.
And also, I would would suggest you to take a look at the bunch of examples on analog output that are available at the following location:
Analog Output Please do let me know if you haev any questions.
Sincerely,
Sastry V
Then
