08-08-2008
07:34 AM
- last edited on
07-15-2025
03:40 PM
by
Content Cleaner
Hi there,
some time ago there was a post about somebody searching for 1easyio.llb.
https://forums.ni.com/t5/LabVIEW/Is-quot-1easyIO-llb-quot-a-National-instuments-LLB/m-p/328072
Now, I have the same problem (in LV7.1) because I have inherited some old VIs (LV6) asking for this library.
As suggested in that post, I tried to install the traditional DAQ: TDAQ741.zip
from
http://digital.ni.com/softlib.nsf/websearch/3DBF3D343476A28F8625709E006A4937
However, after installation I cannot find this LLB in the whole NI folder...
What am I doing wrong? Do I have to install an older TDAQ version?
Thank you for any hints,
Tilman.
08-08-2008 08:30 AM
Hello Tilman,
Thank you for your post on our webforum. Are there more Labview versions on your pc installed? The library's will be installed in the latest version of Labview. It is possible to copy those directories;
You should now be able to use Traditional NI-DAQ (Legacy) with both versions of LabVIEW.
I hope this helps,
Have a great weekend,
Martijn
