accurate fft after dc offset removal
Pls someone should help look at the attached VI. I want to remove dc offset and still obtain accurate fft. In my VI, once I remove the offset the fft only sees the magnitude of the first sample throughot the spectrum. I also do not want to assume that I have an idea of the offset beforehand by simply subtracting its value.
(4,004 Views)
Duplicate thread. Please keep the discussion in the other thread.  The LabVIEW Board is a more appropriate place for this question.
Lynn
(3,986 Views)
