Home
Community
Discussion Forums
Most Active Hardware Boards
Multifunction DAQ
Topic
Multifunction DAQ
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
attach two arrays
attach two arrays
acgraham
Member
12-11-2009
09:51 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
i have two arrays that i want to attach end to end. if i use build array it creates an appended array which is not what i want. essntially im performing the opposite of a split array. are there any functions that match this description?
Go to Solution.
0
Kudos
Message
1
of 3
(3,431 Views)
Reply
Re: attach two arrays
Dennis_Knutson
Knight of NI
12-11-2009
11:48 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Use Build Array. Did you right click on it and select 'Concantanate Inputs'? Do you run LabVIEW with the Context Help window open?
0
Kudos
Message
2
of 3
(3,427 Views)
Reply
Accepted by topic author
acgraham
acgraham
Member
Author
12-12-2009
06:36 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
actually i just found that "insert into array" worked for me. ill try you method too next time
0
Kudos
Message
3
of 3
(3,414 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
