05-15-2012 06:32 AM
Does anyone know of a command reference or programmer's reference document for TCP/IP communication with out using LAB view? I can establish communications with the DAQ from the PACR1 controller but I don't have the commands for triggering RTD modules.
Any help would be greatly appreciated.
Jim.
05-15-2012 10:48 AM
Is the OPTO PAC R1 that you're referring to this product?
The cDAQ-9181 uses a proprietary data protocol implemented via DAQmx, which has both a LabVIEW API and a C API. However, this requires a Windows host in order to have DAQmx installed; the OPTO PAC R1 won't work as a host. You can, however, have a separate Windows host that communicates with both the cDAQ-9181 and the OPTO PAC R1.
