I have a daq card 6024E and a laptop Acer Aspire 3050 w/AMD sempron 3500 1.8 GHz. Win XP SP2
I use MAX 4.0.0.3010 and NIDAQ 8.0.1
When I run MAX and click on Test Panel an error is showed :
This operation can only performed on analog input physical channels.
As configured , this device does not have any analog input connections.Long time ago , With similar device , when I used this tool every channels were showed
And when I want to create a new task a label show:
No supported devices found
I seem An isntallation problem is here.
Note:
In device Manager the IRQ nr is 23
The IRQ showed by MAX is 17 ....?
I will appreciate an urgent Assistance
Ariel
