configure ERROR daq card 6024E? URGENT
I have a daq card 6024E and a laptop Acer Aspire 3050 w/AMD sempron 3500 1.8 GHz. Win XP SP2
I use MAX 4.0.0.3010 and NIDAQ 8.0.1
When I run MAX and click on Test Panel an error is  showed : This operation can only performed on analog input physical channels.
As configured , this device does not have any analog input connections.
Long time ago , With similar device , when I used this tool every channels were showed
And when I want to  create a new  task  a label show:
No supported devices found
I seem An isntallation problem is here.
Note:
In device Manager the IRQ nr is 23
The IRQ showed by MAX is 17 ....?
I will appreciate an urgent Assistance
Ariel
(3,200 Views)
Looking for a solution, I install another device , NI-USB 6009 and show the same Behaviour. Then I use another laptop (Compaq f500) and install thesame device and ,ups! it work Successfully. But I can´t install the PCMCIA device because the compaq has not this port.
Now I test a third devoce NI9221 and it show the same Behaviour( works ok on compaq, no works on Acer)
Smiley Sad
Many thanks
Ariel
(3,189 Views)
Hi Ariel,
Check your system and detect any ant-virus. If you  find NOD32 , please uninstall it
Ariel
(3,165 Views)
Thanks, ariel.
I remove this NOD 32 and then the MAX works OK
Thank you Again!
(3,164 Views)
