‎03-28-2021 02:44 PM
Hi
I have M series multifunction DAQ device and i want to connect this PCI card to laptop. how can i do this? have NI a device suitable for this work?
thanks
Solved! Go to Solution.
‎03-30-2021 01:16 AM
There are PCI to USB converter but NI does not have a solution to connect a PCI card to a Laptop. The use of PCI adapters is a configuration that is not supported by National Instruments. NI don't test DAQ devices with these kind of accessories.
If you need to use a computer without PCI or PCI Express ports, I recommend changing the form factor of your DAQ card. NI offer a variety of USB DAQ devices.
More info is posted here - https://forums.ni.com/t5/Multifunction-DAQ/PCI-to-USB-adapter/m-p/3873270#M96340
‎04-04-2021 08:00 AM
hi
thanks for reply
but in that link said the pci to usb is impossible. and i dont want to change my DAQ device.
Can i use like this converter?
PCI to expresscard
‎04-04-2021 08:13 PM
Let me try to summarize your discussions,
#2 - I do not know completely about the ExpressCard specifications to say if it will work. If you can afford it, I would suggest you take the risk and give try (theoretically it would work).
In any case, NI will not provide support for getting their devices to work with aftermarket modification products and if your instrument is damaged, it will be your sole responsibility.
‎04-05-2021 06:01 AM
As I mentioned before, NI has not tested it's products with third party PCI adapters. It's sole responsibility of the user to test and validate DAQ cards functionality. NI will not support in this case.
I understand your point of view from cost perspective. With the above mentioned limitations, My strong recommendation is to go with NI USB DAQ device or Desktop PC (to work with PCI card) - which might cost lower than USB DAQ (some specific DAQ models).
Regard's,
Dharani Rajagopal | Certified LabVIEW Architect
‎04-06-2021 08:12 AM
hi
ok thanks i test it.
‎01-06-2022 04:29 PM
I am also facing the same issue.
Did you find any reasonable solution? Could you please share it?
Thanks!
