Multifunction DAQ
connecting PCI-6014
I have a PCI-6014, and I use SH6868 cable to connecting between PC and 68-pins of PCI-6014. But I don’t know how to connecting between PCI-6014 and transducer. The transducer is an accelerometer named pv-90I (Rion Company, Japanese). So my question is: How can I connecting PV-90I to ch#3 of PCI-6014. May I connecting PV-90I to the ch#3 in 50-pins remain? Thank for visiting and answer me. I’m very exceedly  grateful :-x
(3,349 Views)
Accepted by saker
Hi saker,
To connect a sensor to your PCI-6014, you will need to have a connector block to provide easy access to the inputs and outputs of your hardware. Since the PCI-6014 does not have direct signal connectivity, you will need to use a connector block as an interface between your hardware and your sensor.
Tommy G.
Product Manager - Search, My Account, and Chat
(3,338 Views)
Thank you very much!
(3,327 Views)
