convert and plot unscaled data from Labview to scaled Matlab
I want plot data that was acquired with Labview in Matlab. I have looked over the Graph Aquired Data VI and the Cont Acq&Graph Voltage-To File(Binary) VI but I can't quite figure out what they are doing in the Convert Unscaled to Scaled sub-VI. I have 60 channels and the header contains three items for each which I believe are SampleClk.Rate, Offset, and AI.DevScalingCoff (or gain maybe?).
What is the equation for converting raw binary data to something with the same plot that the above Labview VIs have? I am using a PCI-6071E on a XP pc if that makes a difference.
Thanks!
(3,216 Views)
Hello Richard Z,
It looks like you want to use Matlab to plot the data that you have acquired in LabVIEW. Here are some resources that you can reference:
How LabVIEW Stores Data in Memory
Discussion Forum:
How can I read labview 7.1 binary data into matlab 6.5?
Discussion Forum: How to read scaled data in Matlab?
With regards to your other question on what the convert unscaled to scaled vi is doing. Double-click on the subvi, this will open the subvi to display the front panel. Press ctrl+T, to tile the front panel and the block diagram. You will then see how the waveform is built. The value of the waveform component is a polynomial of the offset, data raised to the power y multiplied by the gain. I think the best way is if you take a look at the code for better understanding. Please let me know if this is still unclear.
  Sandra T.
Applications Engineer | National Instruments
(3,201 Views)
