Multifunction DAQ
create differential signal from 6289
Is is possible to create a differential sine wave on the output of the 6289? And how would I do this.
I created a differential DC signal by making AO0 positive 1V and AO1 negative 1V. Then measured the signal on a differential input ADC, which is my DUT.
Now I am trying to trim CMRR and wanr to use the DAQ6289 because I don't want to add another piece of equipment to the test plan.
Any ideas would be appreciated.
(3,762 Views)
Could you please specify what you mean by differnetial AC output? One way to do this is to output an AC signal with a DC offset and measure it accross a constant that's the same as what the DC offset is. For example, have one output be an AC signal with an offset of +1VDC and have another which outputs a constant +1VDC. Is this what you are trying to accomplish?
Daniel G.
ni.com/support
Daniel G.
Semiconductor & Wireless
(3,740 Views)
This is now for my interest as I have found a work around.
BUT
What I was attempting to do is produce a sine wave @ 1V, 60Hz on pin AO0 and a sine wave 180 degrees out of phase on the AO1 pin.
Is that possible?
(3,729 Views)
Accepted by BeanBoy
Please take a look at this example to see how to generate off phase sine waves:
http://zone.ni.com/devzone/cda/epd/p/id/5001
Have a great day!
Daniel G.
www.ni.com/support
Daniel G.
(3,714 Views)
