current measure with 6023e
I have to measure the current with 6023e DAC. Is there a possibility to connect the current signal directly to the card analog input, or do I have to convert this signal to voltage signal (eg. using small resistor)?
Thanks for Your answers,
Radek
(2,670 Views)
Hello Radek,
You do need to convert the signal to a voltage using a precision resistor. 249 ohms is a common value for currents in the 20mA range. I have also used precision 0.05 ohm resistors to read DC currents approaching 100 amps.
Doug Norman
(2,670 Views)
