Multifunction DAQ
current measurement
how to measure current using current sensor and fetch the current sensor data through ni hardware.
which c series module i can use??
(3,327 Views)
Accepted by Risuraj
current measurement.jpgMore info needed. Can you share the specs or data sheet on your current sensor ? Type? Application? Range, bandwidth,  update speed, data transfer type, USB,, i2C, etc. ? The more info, the better. You could use a less expensive analog voltage input module; see attached dwg.
(3,280 Views)
i have attached the datasheet of current sensor and schematic(connector) where input is 24v and output is 12v,4.2A,50.4Watt.so i want to measure the output current 4.2A using current sensor.i have NI 9201 AI module.can i use this module for my application.please share connection diagram.
(3,270 Views)
Accepted by Risuraj
The datasheet says that your LA 200-P current transducer has  1:2,000 transfer ratio (K) where 200 amps-in  produces 100 ma out.
Your 4.2A measurement would produce 2.1 ma output.
Your NI-9201 is a (+/- 10v) voltage input device.
If you wanted 2.1 ma to produce half scale ( 5V), then a current sense resistor (RM) of about 2.4K ohm, 1/8 watt would work fine. See attached diagram.
Note1: The LA 200 is an AC/DC transducer. if you are measuring 4.2 Amps AC, then the 2.1 ma output will be AC as well and the 2.4K resistor will produce +/- 5 vac into the NI 920.
Note2: The above information is my best guess, quasi-solution or approach for this forum-submitted question, without knowing all the facts or circumstances. Proceed or approach this solution at your own risk. The above suggested solution should be confirmed with the LA 200 MFG and other industry professionals before proceeding. Test the Rm voltage output before completing the connection to NI 9201
Good luck!
(3,237 Views)
i want to replace the current sensor with INA250-Q1 texas current shunt monitor.The same AI module i am using here.how i will make the connection.i have attached datasheet with this post.
(3,092 Views)
