Returning to NI and Borland Delphi after long absense. I am using Delphi 5 and 6, NIDAQ 6.9, and a NI-6025E card.
I cannot compile new Delphi code. My problem(s) look like this:
First, Delphi does not want to find NIDAQ ([Fatal Error] Unit2.pas(49): File not found: 'nidaq.dcu'). Seems like a library directory problem but I can't solve it. I might get close though---
Next, after adding some library directories, Delphi finds NIDAQ but returns two error messages: [Error] nidaq.pas(820): Undeclared identifier: 'pf32' and then [Fatal Error] Unit2.pas(49): Could not compile used unit '..\..\..\..\Program Files\National Instruments\NI-DAQ\Include\nidaq.pas'.
Could some kind soul please stamp out my ignorance?
By the way, I can drive the board just fine with the test bench sofware provided in NIDAQ and I also do just fine with previously compiled Delphi code.
Thanks much,
