09-12-2011 07:54 AM
I am building a data-acquisition program and i want to store the data and it's events in EDF+ Is there someone out there who allready made such a VI? I used to do it in EDF, but now i also need events data.
Thijs
09-13-2011
01:16 AM
- last edited on
09-14-2026
12:08 PM
by
Content Cleaner
Dear Thijs,
We do have a data plug in for this, you are able to use a data plug in using the functions of the storage / data plugin palette (starting with LabVIEW 2010), if you have an earlier version; please use the llb's from this [link removed; example no longer available] example.
09-13-2011 02:18 AM
Is it also possible to write EDF+ files with these vi's?
Thijs
09-13-2011 02:38 AM
Thijs,
please see the plug in; it also supports EDF+
09-13-2011 06:54 AM
Thank you, i see that the annotations isn't supported yet... And that was the thing i needed it for, well then i'll have to write it myself, should work, also did it in the past with EDF...
Thijs
09-14-2011 05:18 AM
Dear Thijs,
Bad to hear that the plugin doesn't contain the feature you needed. It is planned for the future, but I can't say when it will be implemented. It is always good to bring it to the attention of our developers; you can use Idea Exchange for that.
Don't hesitate to post when you have any problems when implementing the EDF+ format.
