edf plus
I am building a data-acquisition program and i want to store the data and it's events in EDF+ Is there someone out there who allready made such a VI? I used to do it in EDF, but now i also need events data.
Thijs
(3,790 Views)
Dear Thijs,
We do have a data plug in for this, you are able to use a data plug in using the functions of the storage / data plugin palette (starting with LabVIEW 2010), if you have an earlier version; please use the llb's from this example.
Martijn S
NI Netherlands
(3,784 Views)
Is it also possible to write EDF+ files with these vi's?
Thijs
(3,781 Views)
Thijs,
please see the plug in; it also supports EDF+
Martijn S
NI Netherlands
(3,779 Views)
Thank you, i see that the annotations isn't supported yet... And that was the thing i needed it for, well then i'll have to write it myself, should work, also did it in the past with EDF...
Thijs
(3,777 Views)
Dear Thijs,
Bad to hear that the plugin doesn't contain the feature you needed. It is planned for the future, but I can't say when it will be implemented. It is always good to bring it to the attention of our developers; you can use  Idea Exchange for that.
Don't hesitate to post when you have any problems when implementing the EDF+ format.
Martijn S
NI Netherlands
(3,768 Views)
