inductive proximity sensor with DAQ
Hi everyone
I am planing to connect my inductive proximity sensor with NI-9215 DAQ but not sure will that thing work perofectly. Also i don't know how to connect my sensor with the BNC terminal.
The sensor I am using is from automation direct AM9-05-1A with input volatage of 10-30 VDC and output voltage range from 0-5 VDC.
I want DAQ to monitor my output signal from sensor.
(6,435 Views)
What DAQ device are you using? What is the BNC "terminal" connected to?
It appears that the sensor comes with a 4-conductor connector. Two pins will need to connect to a power supply. Two pins will connect to the DAQ input. One of the two pins in each case is the ground, common, or L- pin.
Lynn
(6,422 Views)
Hey lynn
I am planing to use NI-9215 DAQ. Here is the link for that.
https://www.ni.com/en-us/shop/model/ni-9215.html
Since this kind of DAQ has BNC type of connectivity with it so I am not sure how to connect my sensor with this connector.
(6,412 Views)
I have cDAQ - 9174 with me as chassis option
(6,410 Views)
Accepted by rodeo87
It appears that you have two choices.
1. Cut the connector off the sensor and wire the appropriate conductors to a piece of coaxial cable with a BNC plug (and separately to the power supply).
or
2. Get a jack which matches the plug on the sensor cable and wire its terminals to a coaxial cable with BNC plug and to the power supply.
Lynn
(6,392 Views)
Thanks Lynn
(6,370 Views)
