Multifunction DAQ
maximum sampling rate (pci-6070e , multiplex mode)
Dear Sirs
 For Data Acquisition from SCXI-1000 (Consist of  two modules SCXI-1121) in multiplex mode I am using  PCI-6070E and  an Example in LabVIEW 8.0 (Cont Acq & Graph Voltage-Analog SW Trigger.vi) and  my request is one-eighth (1/8) of maximum sampling rate  , but maximum sampling rate is 41666.7 ,  what is my problem? Please!
Best regards
H.R. Tajik
hamidreza_tajik@yahoo.com
(2,879 Views)
Hi H.R. Tajik,
I recommend checking the following Knowledge Base. It gives a good idea on how the sampling rate is calculated on the SCXI chassis.
Best of Luck,
Faris
Bueller
(2,845 Views)
